Xerox 6204 Light lines on copies
  • manuelubau
    • Aug 2011
    • 62
    Hello Everyone,
    I am facing an issue with very light lines on copies on a Xerox 6204. I noticed that the magnetic roller does not have a uniform distribution of toner on it. does anyone know how to fix this besides replacing the roller? I have tried cleaning the roller and replacing the blade however the issue is still there.
    Thank you!
  • Tecnico_Xerox
    • Jan 2019
    • 54
    Re: Xerox 6204 Light lines on copies
    Hello.
    In this case you need to polish the Developing Unit with a fine non-metallic brush, remove all the toner stuck on the surface of the roller. Then you need to change the magnetic roller cleaning blade.
    Good luck
