Wc 7830 image problem
  • Codex
    • May 2008
    • 704
    Hello guys
    I have a strange problem, on every full color print i have many white "dots"... If i use the "repeated defects sheet" nothing matches the distance of my defect, that is 25mm from dot to dot. I've already changed all 4 Pcu's from a working machine but nothing changes. The transfer belt seems good, the fusing unit is perfect.... Any ideas?
    Thank you!
    This gallery has 1 photos.
    Memento Audere Semper
  • adriansto
    • 2387
    25 mm = first BTR
    • ROBERT SANTOS
      • Dec 2024
      • 5
      Bom dia.
      ja verificou os LPH, Belt de trasferencia?
      Grato, Robert
      • mindhunter
        • May 2008
        • 146
        Drum and foam roll needs to be changed
        • Codex
          • May 2008
          • 704
          Hello
          it was the transfer unit for me, maybe one of the internal rollers.Thank you for your suggestions
