altalink c8045 output
  • ps22sp
    • Aug 2014
    • 83
    205 FCBA t5.pdf see pic thanks for comment
  • xcopytech
    • Aug 2006
    • 1794
    Print single page halftone from diagnostic, then for affected color clean led bar and check developer
    • mindhunter
      • May 2008
      • 146
      Seems blue developer units uas debris. Clean lph and sieve your developers.
      • shinchan
        • May 2011
        • 197
        May I know whats the sieve number do you use?
        I use T61, most people use it for clothes printing
        • senas
          • Dec 2024
          • 4
          not sure but, check the drum unit yellow I got same for black drum unit ,it was waste toner spiral block and drum got damage ..
          • mindhunter
            • May 2008
            • 146
            Dont take it too hard. You can even use women stockings. As long as it separates hardened toners from developer , its ok. And remember only use xerox genuine toners Before seiving. And print at least 500 page by genuine toners. If your toner has rubbish, it is only waste of your time
            • mindhunter
              • May 2008
              • 146
              It is happening when you put fake or not the specific toners of machine toners on these copiers. The reason is 60% of fake toners will directly goes to waste toner box and waste bottle will filled to fullest amount rapidly.about one or two weeks it will fulled. So waste block the whole path of recycle. In consequence it will break down the whole gears and also spiral moxer behind the blade or even scratch drum if spiral material is metal. All in all , fake toners are just mess.I saw some people use even konica minolta toners for these copiers because they think its cost efficient.
              Bottomline, use only genuine toners
              • ps22sp
                • Aug 2014
                • 83
                Magenta and black developer replace, magenta ,cyan toner replace oem
                now print about 200 pages missing magenta color
