XEROX D110 Won't boot up
  • Fairandsquare
    • Jan 2025
    • 5
    It will power up the fuser and it seems to start doing system checks but the dislay stops on page 1/6 and will stay like that. I've shut down, re-started, unplugged and restarted, checked the power. At a loss.
  • Milo Wilson
    • 499
    Check the front door interlock switch.
    • xcopytech
      • Aug 2006
      • 1792
      Start long boot diag mode to see will you get any error code.
      Check memory on ESS PWB and if still same replace ESS PWB
      • Fairandsquare
        • Jan 2025
        • 5
        Interlock is working
        nothing happens if door is ajar
        • Fairandsquare
          • Jan 2025
          • 5
          Very much a novice. Can you provide a procedure?
