Versant 80 won't print black (K)
  • MRJESSE
    • Jun 2017
    • 41
    You will need to replace the developer bias for K. 105E17732 should be the part number.
    • stev0
      • Dec 2023
      • 26
      We tried that already, no luck.
      • MRJESSE
        • Jun 2017
        • 41
        You made sure it was the K HVPS? Not for cyan?
        • stev0
          • Dec 2023
          • 26
          #19
          We're going to check further into that tomorrow. Thanks!
          • stev0
            • Dec 2023
            • 26
            #20
            I think we changed out the wrong one, we were just looking on the back side and swapped out the Y and M... I found a service diagram and it turns out K and C are on the left side which we didn't see because of the high capacity tray module. Any idea if it's the top or bottom one?
            • adriansto
              • 2369
              #21
              The outboard one = right side on your picture.
              • stev0
                • Dec 2023
                • 26
                #22
                Thanks, we'll give that a shot!
                • stev0
                  • Dec 2023
                  • 26
                  #23
                  That worked! Thanks for the help guys. One more follow-up question... In the process of troubleshooting I had initialized NVM and IOT NVM, a color registration issue started after that (see attached). Any idea what we have to do to calibrate that? Tried the image quality adjustment and a couple other things but no luck.
                  ** edit ** Fixed this, we must have fried a drum during the process. All good now!
                  • stev0
                    • Dec 2023
                    • 26
                    #24
                    I'll just add this to the thread in case anyone else experiencing the issue comes across this thread... after swapping the K Developer bias HVPS, the K toner NVM was set to 1 due to the issue, I reset that to 0 before attempting to print with the new board to reset the error. Here are the NVM codes for resetting the toner dispensing error.
                    Taken from Partsdrop.com / author Britt Horvat
                    Once you solve the problem and replace developer if needed, you will need to reset the Fault Code from diagnostics. I recommend leaving that to a trained technician. Below is a list of the fault codes for each color and the associated NVM Read/Write code that you would need to clear back to "0" to clear the code and get the machine to try to tone up again:
                    TONER DISPENSE FAULT CODES AND NVM Chain-Link codes to clear back to 0:
                    Black Fault Code: 093-317 (NVM Code = 761-265)
                    Cyan Fault Code: 093-316 (NVM Code = 761-264)
                    Magenta Fault Code: 093-315 (NVM Code = 761-263)
                    Yellow Fault Code: 093-314 (NVM Code = 761-262)
                    • stev0
                      • Dec 2023
                      • 26
                      #25
                      Well... Having a couple of other unrelated problems now that I can't seem to figure out 😐 Randomly it seems to be purging paper, shows an error message saying purging unusable paper and it prints a very light version of the sheet. There's nothing wrong with the paper. Sometimes it works again right after and sometimes not. Sometimes it works great for a while, then decides to be a pain. My black developer also seems to be disappearing (into waste container I think). Did an IOT initialization to see if that helps with the developer.
                      Any idea what could cause this?
