Hello, Please I need help to fix A4 paper jamming and getting stuck in the fuser exit on xerox J75. Paper was removed and I've checked everywhere and had found no obstructions but still getting paper jam on A4 paper only. I've replaced the fuser and the sensor under the fuser unit but has not fixed the issue. I've only been printing on SRA3 and cutting to A4. I'm getting these error codes when I printed the error history.: 077-103, 077-111, 048-100. Any assistance would be appreciated greatly.
Xerox J75 Error 077-909
Tags: None
Thank you. It only jams on A4 bond paper on all trays. I will try your suggestion and let you know how it goes. Thanks again!Comment
Thanks mate for your help...when printed on Xerox 120gsm A4 bond, it runs through the machine with no issues. At the moment, I'm out of the 80-100gsm stock which I'm yet to test. Thanks again, much appreciated!.Comment
