Rank Xerox - DC CS 50
  • Robert
    • Sep 2025
    I've installed the printer (without Centerware) - and it does not work. It is properly recognised by the system, it works as a scanner - but it does not work for printing. Is there any setup to be made in the printers panel?...
    When i do try to print a test page - it stops "processing" and stays this way.
    The printer is seen in the network - i gave it an IP and the interface is loading in the browser. I just dunno what's happening...
  • xcopytech
    • Aug 2006
    • 1793
    use lpr port and queue name lpd
    • Robert
      i get fault codes: (reading from /sys_admin.html -------> properties):
      6-300.
      LPD/LPR are enabled.
      • adriansto
        • 2395
        6-300 inseamna capac document deschis; nu are relevanta la tiparire.
        Tiparirea prin lpr inseamna sa incarci serviciile de tiparire unix in XP si sa folosesti aceste servicii pt tiparire la portul default 515. Denumirea cozii de tiparire ceruta in fereastra de configurare a serviciului de tiparire este lpd
        • Robert
          still not working...
          • adriansto
            • 2395
            You must use documentation for your Fiery.
            Xerox Document Management, Color Printers, Copiers, Business Consulting Services choose support, choose Docucolor 12 and you'll see documentations and drivers.
            • Robert
              In my searches to make the machine work, i assigned DHCP instead static ip. Now it is unseenable by the network, no matter i scan the network for it. Is there any possibility to re-enable the static IP from the control panel of the machine? (As long as it is not seen in the network, i cannot access it from the computer...)
              L.E. These questions may look silly, but i'm a noob and the documentation completely lacks. So - i'm on it as blindly as possible. Thanks for understanding...
              • adriansto
                • 2395
                Deocamdata asta am gasit. Cobra vine pus numai pe DCCS50 iar in tara s-au vindut DC12
                Document Centre ColorSeries 50 User Documentation
                Document Centre ColorSeries 50 Drivers and Downloads
                • Robert
                  Le-am luat si noi pe cele de pe site-ul xerox si le-am instalat. Acum schimbaram si modulul de rip, resetaram 2 valori NVM - si copiatorul apare din nou in retea. Dar tot nu printeaza. Suspectam ca ar putea fi "handicapat" din valorile NVM sa poata fi folosit doar la scan si copy, si nu la print. Iar butonul de auditron este disabled,
                  What does 3-7 error mean?
