Xerox 560 Issue with Magenta Toner
  • Oldtimer
    • Oct 2008
    • 17
    I've printed a sheet of 11x17 full flood of each color CMYK. My magenta has a void area on the non operator side going the full length of the sheet. 17". I've replaced the toner cartridge and put a new drum and even tried a different fuser. All have the same results. See the attached. Any suggestions would be appreciated.
    This gallery has 1 photos.
  • xcopytech
    • Aug 2006
    • 1794
    Clean ROS glass
    • Milo Wilson
      • 502
      Also check magenta developer mag roll for blockage.
      • Dech1
        Senior Engineer
        • Dec 2022
        • 61
        c lean ros glass. or remove ros and clean properly then repace suction filter(very important to replace filter)
        • Oldtimer
          • Oct 2008
          • 17
          Originally posted by xcopytech
          Clean ROS glass
          Thank you, I will give that a try an let you know the results.
          • Oldtimer
            • Oct 2008
            • 17
            will do thank you, i'll let you know if it worked.
            • Oldtimer
              • Oct 2008
              • 17
              ok thanks for that.
              • Oldtimer
                • Oct 2008
                • 17
                That did it. Much appreciated.
