xerox versant 180 - jam problem
+ More Options
Posts
  • Ogin87
    • Aug 2024
    • 17
    hi
    we use UPS for our machine xerox versant 180
    we had a problem with the UPS while the machine was running
    UPS replaced with new one
    then the machine runs and print one copy well
    but when we print more copies the paper jam in the interface and finisher
    I tried download mode
    then replaces the PWB board
    still same problem
  • adriansto
    • 2387
    Originally posted by Ogin87
    hi
    still same problem
    And error code ?
    • Ogin87
      • Aug 2024
      • 17
      no error code
      just paper jam
      • Ogin87
        • Aug 2024
        • 17
        this is error history
        • adriansto
          • 2387
          48-102:
          IFM output sensor contaminated. Clean the sensor for paper dust and dirt.
          Check drive tabs on IFM drive gears are worn down & slipping.
          For others errors it is good ideea to have service manual for V80.
          • Ogin87
            • Aug 2024
            • 17
            hi Adrian how are you
            I have service manual
            i email you before for old problem
            and you sent me the manual
            • adriansto
              • 2387
              OK you can find on IFM service manual about the 48-102 error code. Also in the history look at the other errors and check if there are the problems with machine. You can note the actual errors, delete the history and watch what error appear after.
              • Ogin87
                • Aug 2024
                • 17
                all sensors of the finisher and the interface has been cleaned
                problem solved
                thank you Adrian
                • adriansto
                  • 2387
                  problem solved
                  thank you Adrian
                  You're welcome!
