Problem with color magenta xerox 560
  • dacam20590
    • May 2019
    • 30
    i'm have problem print color xerox 560.the magenta has really disappeared I don't know why
  • bojans
    • 1313
    Re: Problem with color magenta xerox 560
    [ATTACH=CONFIG]50918[/ATTACH]
    First check Does the developer rotate? Check gears.
    • dacam20590
      • May 2019
      • 30
      I changed the developer magenta and still can't print in magenta
      • jhalfhide
        • Apr 2015
        • 452
        Metal contact at rear of developer housing should contact a spring at the rear of the machine. Sometimes the spring (held in a small black plastic piece) can break.
        Pull out main draw, IBT drawer and drum/Dev drawer and shine torch inside. Look for the 4 black Dev contacts and look for damage. Also check back of Dev housing to ensure metal contact is straight and not bent.
        Sent from my LYA-L09 using Tapatalk
        • dacam20590
          • May 2019
          • 30
          I think this spring is the problem, I see it is bent
          • Tecnico_Xerox
            • Jan 2019
            • 54
            Hi Dacam.
            First check if the Magenta Development Unit is spinning, Take out the unit and manually check if all the gears move when spinning, usually if it doesn't it is because the gears break and need to be changed. If the development unit is fine, I recommend you check the Developer Drive Assembly, in some cases there is a gear that breaks and is responsible for turning the development unit.
            Good luck.
            • magicaljake
              • Jun 2018
              • 22
              the power supply for magenta could have failed... in which case all of the magenta developer would be depleted... I've seen it before in a 550, only in yellow.
