noise problem
  • azmady
    noise problem
    Hi all. I would like to enquire about copier like Document Centre II C3000 . Any tips on what is the good step by step to troubleshooting noise problem. screeching etc...
    Q2. Where is the function to know on the CP what is the IP address assign to the printer .
    Q3. Anybody has the various chain function for DC 286 , 250 , 240 , IIC3000 , 236 ...etc
    mtks n brgds
  • digital copier resources
    The B
    • Apr 2006
    • 10
    I place a stethoscope on the machine and use it to pinpoint where the noise is located. Then just look at that section and take it from there by cleaning, lubricating, and using my eyes and hands
    • copytech200X
      • 264
      noise problem?varenne machine had latest firmware to minimize the drum rotary motor turns more than four times ..usual start up machine runs 6 times or after power save mode drum rotary motor turns 5-7 times ..
      • Sgt. Hulka
        • Jun 2005
        • 95
        Step 1. Locate the noise (it is the part making the noise)
        Step 2. Correct the noise issue.
        Step 3. Done
        Who wants a Hulka Burger?
        • TechMate
          • Mar 2008
          • 285
          press the login/logout button. enter pw '11111', systems settings, network settings, TCP/IP settings
