Need Help with Double-Sided Labels Printing Issue - C9065
  • CopierGuysCLT
    • Jul 2023
    • 2
    Have a weird one, double sides labels, first ive seen of this cant print with selecting label resources, so have it as lightweight but since they are labels we need to lower the fuser temparture so it doesnt start curling and peeling the labels oI’ve got a tricky one—first time dealing with double-sided labels. I can’t print them using the "Label" setting, so I have to use "Lightweight" instead. The problem is that since they’re labels, the fuser temperature needs to be lower to prevent curling and peeling.
    I’m trying to find where in the maintenance settings I can lower the fuser temperature and slow down the feed rollers on a Xerox Primelink c9065. Any ideas?
  • joyousenrol
    • Mar 2025
    • 2
    Ah, I see what you're dealing with. Double-sided labels can be tricky, especially when you're trying to avoid curling and peeling. On the Xerox Primelink C9065, you can usually adjust the fuser temperature and feed speed in the printer's Print Settings or Maintenance menu. To lower the fuser temperature, check if there’s a "Paper Type" or "Media Type" setting where you can adjust for labels or a lighter weight paper. For slowing down the feed rollers, there might be a setting under "Advanced Settings" or "Speed Adjustment" for specific media types like labels. If you're not seeing these options, try reaching out to Xerox support—they should be able to walk you through it, or it could be in a firmware update. Just be cautious when adjusting these settings so you don’t cause issues with other types of print jobs. Good luck!
    Tags: #XeroxPrimelinkC9065 #LabelPrinting #FuserTemperature #DoubleSidedLabels #ragdoll hit printquality
    • Tag Game
      • 1
      "Adjusting the fuser temperature and feed speed on the Xerox Primelink C9065 can significantly improve print quality for double-sided labels, reducing issues like curling and peeling. Good luck!"
      Tags: #XeroxPrimelinkC9065 #LabelPrinting #FuserTemperature #DoubleSidedLabels #tag gameprintquality
