black traces
  • houly
    Non-tech
    • Apr 2015
    • 30
    black traces
    Hello all,
    I would to know how I can deal with black traces on my WC7830 like this image (roll marks ?)... what can I do to solve this problem ?
    thanks for your help.
    best regards
  • nikolai.aleksie
    • Feb 2016
    • 177
    Re: black traces
    to begin with, measure the distance between the marks
    • houly
      Non-tech
      • Apr 2015
      • 30
      Re: black traces
      Ths distance between marks is 81mm
      • nikolai.aleksie
        • Feb 2016
        • 177
        Re: black traces
        • houly
          Non-tech
          • Apr 2015
          • 30
          Re: black traces
          Many thanks for your help, So do I need to replace this part ? do you know the exact ref of this part ?
          • Jack79
            • Jul 2014
            • 312
            Re: black traces
            You can clean the roller and you should be good if it's not damaged of course. You need disassemble ibt unit.
            • houly
              Non-tech
              • Apr 2015
              • 30
              Re: black traces
              Hello Jack79 and thanks for your reply,
              Could you please tell me where is the ibt unit ?
              I have just downloaded the operation manual of the 7800 series but I'm a little confused between terms : does the ibt unit correspond to the ibt belt ?
              which rollers are concerned on the following diagram ?
              thanks for you help
              • nikolai.aleksie
                • Feb 2016
                • 177
                Re: black traces
                thanks for you help
                Check your PM
                • Jack79
                  • Jul 2014
                  • 312
                  Re: black traces
                  thanks for you help
                  IBT unit I mean primary transfer belt unit. You need to remove fuser, locking lever behind the front door, itb cleaning unit, open left door to the service position, remove 2 brackets (if I good remember) and then slide the itb out. The roller which need to be cleaned is located under the belt (inside the belt unit) so you need to remove ibt sleeve (disassemble ibt unit). If you are not familiar with this you must be very careful to not damage the belt surface.
                  • houly
                    Non-tech
                    • Apr 2015
                    • 30
                    Re: black traces
                    thanks for your reply, I hope that I will be able to do it !
                    • shinchan
                      • May 2011
                      • 194
                      Re: black traces
                      Hello all,
                      best regards
                      Clean all rollers inside the IBT ASSY...
                      most of the time, the IBT sides rubber becomes sticky and pieces of the rubber stick inside the IBT or rollers.
                      if the sides rubber already destroyed, then change the whole IBT belt.
                      • Mysrtx
                        • Oct 2021
                        • 1
                        Re: black traces
                        This is a transfer belt roller issue. There is debris or toner built up on the inner ITB rollers causing a ripple/fold/bend on the belt. If you can't get/afford a new ITB unit remove the belt, scour and wipe the ITB rollers with a clean dry cloth, you can use a little alcohol if needed on the metal rollers. If the buckles are to distinguishable on the belt unit replace the belt.
