XEROX 5875 R2, R3 Incompatible
  • derbi246
    • Oct 2017
    • 1
    Hi all, when i replace the Drum module R2 the machine says the R2 module incompatible. I try Altboot with no luck.
    Do i need supply plan activation code??
    Serial no. 3660594123
    Tnx in advance!!!
  • adriansto
    • 2387
    Re: XEROX 5875 R2, R3 Incompatible
    Tnx in advance!!!
    What error code machine display ? Do you know to use activation code ?
    Probably you'll need to pay for the code.
    • xcopytech
      • Aug 2006
      • 1794
      Do you have 113R00672 (metered) or 11300673 (sold) drum unit?
      • IGEN93
        • Jul 2018
        • 49
        Tnx in advance!!!
        you need to change the serial number , date and time and service plan to C with service plan code .
