Xerox C60 Black lines and toner splatter
  • axslinger
    • Jul 2011
    • 6
    I have a Xerox C-60 with integrated rip, with 278K total impressions. There are dark lines (front to back, not feed direction) and looks like toner splatter on the prints and copies. What could be the cause of this? Thank you for your opinions.
  • romario
    • Jun 2020
    • 193
    Re: Xerox C60 Black lines and toner splatter
    I have solved several machines with these problems, from series 4 to series 8, the first thing I do is turn on the machine with the yellow reset key, I enter service mode, initialize data, turn off and turn on the machine, it gives me an original error and I go back to load base firmware, and it is solved, try to see if you are lucky
    thanks
    • tmmdmmm
      • Apr 2021
      • 173
      Wrong thread, wrong machine
      • XEROX_1111_TEC
        • Aug 2019
        • 71
        Did you print any sticky paper suport?
        Did it started from nothing or you started to see that going stronger over the time?
        In point to three possible problems, IBT cleaning blade, drum K or K developer leaking. But my first choice is IBT cleaning blade needing to be clean or you need a new IBT.
        • njshenking
          • Jan 2022
          • 7
          鼓k或k显影剂
