Hi all !
I have a problem with a Xerox WC 7132, that bend paper just before printing the image on it (see pictures). No codes.
The printing was good before we moved the machine, so i check all the mechanical parts that i have access to, and replaced the fuser in case of. Also checked the geometry of the chassis to see if something get bended during transportation, but all is square and nice.
The fold happends in all configuration , from tray 1 to 5 , with A4 & A3 , color or B&W. I have located the problem at the registration phase, so i enter service mode and tested various clutches & solenoid, that seem to works well, except for the registration roller #5 on the figure attached below : the clutch #6 seem to work, but the roller do not turn when i simulate a print.
From what i understand from the service manual, this is the IBT. When i try to test it in service mode , I should be able to check the registration sensor and the transparency sensor, but the CC[089-100] & [089-101] are not availlable to check in the IO check mode ?!?
so I'm a little stuck here, and would appreciate any advice or tip how to go on with the troubleshooting.
Thanks in advance and have a good weekend !
