Migrate from Fiery to Postscript - Color 550
Re: Migrate from Fiery to Postscript - Color 550
As xcopytech said, just leave the VSEL pwb in there, assuming you don't have the jumper pwb, which can be hard to get. It can run without a Fiery attached, using Postscript on the built in green controller, even while the VSEL is still installed.Comment
I will try that and post what result do I getComment
UPDATE
Your tips were follow and the problem was detected. The postscript pwa contacts were not totally clean so that was generating that error. After cleaning the contacts and reinstalled the the VSEL pwb it worked fine.
Thanks a lot for your help.
Keep safe and thanks once more.Comment
