Xerox WorkCenter 7775 Network issue
  • chemicalx50
    • Apr 2014
    • 39
    Good day,
    i have a xerox 7775 that not giving me any i.p. connectivity dhcp or static i am unable to ping the printer is it possible to print via usb port? is there anything i could try?
    i have also did a reset and that didnt change anything
  • adriansto
    • 2388
    Re: Xerox WorkCenter 7775 Network issue
    Originally posted by chemicalx50
    Good day,
    Post here machine configuration report.
    • xcopytech
      • Aug 2006
      • 1794
      Have you check in tools is machine maybe offline
      • chemicalx50
        • Apr 2014
        • 39
        Yes I did it's not.... the connectivity light works but not getting a i.p. address even if I set it to static I'm unable to ping. Can I install a pci adapter and if so how do I enable it? I see that the machine has pci slots available
        • xcopytech
          • Aug 2006
          • 1794
          Print configuration report.
          Reload system software.
          • chemicalx50
            • Apr 2014
            • 39
            Need help asap!!! ๐Ÿ˜ญ๐Ÿ˜ญ๐Ÿ˜ญ๐Ÿ˜ญ what to do if my 7775 has a bad network port??
            Connectivity light works but just getting a i.p address and unable to ping printer works perfect otherwise.
            Any help greatly appreciated
            • Sn0wlink
              On-Site Engineer
              • 35
              Can you post us the configuration page, please.
              There's the tool the works, Then there's the tool that is Right!
              https://www.sn0wlink.com
