VersaLink C7025 – Yellow Color Misalignment
  • janik123
    • Feb 2024
    • 30
    [Misc] VersaLink C7025 – Yellow Color Misalignment
    Hi everyone,
    I’m working on a Xerox VersaLink C7025 that has a yellow color shift/misalignment issue. So far, I’ve tried the following:
    • Replaced the yellow drum unit with a new one
    • Cleaned the yellow LPH (Laser Print Head)
    • Checked the yellow developer – everything looks normal
    Despite this, the yellow still appears shifted. I’m starting to suspect the issue might be related to the IBT (Intermediate Belt Transfer) assembly — possibly not seated or aligned properly. Could the belt cause a single color misregistration like this?
    Alternatively, could the fuser cause yellow shifting? I haven't seen any major defects from it, but just considering all angles.
    Appreciate any advice or insights!
    Thanks in advance.
  • adriansto
    • 2387
    Check and clean MOB sensor.
    • shinchan
      • May 2011
      • 195
      agreed.
      also do calibration .
