Xerox 6250
  • DavidEtling
    • Feb 2005
    • 31
    Xerox 6250
    Have a Xerox 6250 that intermittently jams. After 9 or 10 pages a page is almost out the delivery assembly and one is 3 inches out of the fuser. Have replaced feed rollers and fuser with no significant change. Any help would be appreciated! David
  • jdwaterman
    have your fix
    You need a fuser snippit email me and I will send it back on the reply You load it by using centerware wicth is the IP address in the address bar of a internet browser when the printer web page comes up go to thr print tab, then file download browse for the file and click on the print icon.
    • Fire4Effect
      Hi JD,
      I have the identical 6250 fuser jam described above.
      Would you please send me the fuser snippit you posted about.
      Thank you,
      Howard
      • Fire4Effect
        Those looking for the Fuser Stall Snippet can download the file here:
        Fuser Update Files
        • rfaxman
          Xerox Phaser 6250 - Service Menu
          Phaser 6250 - Can anyone tell me how to access the service menu for the Phaser 6250, or how to bypass the toner chip?
          I have spent a good deal of time searching for this here and on other forums so I don't think its already answered; my apologies if I missed it! (and please point me to it)
          The Xerox Phaser 6250 Toners have a chip or RFID tag that the 6200's do not have, that is used to detect and track toner cartridges.
          My question -- Part A -- Is there a way to bypass reading (or RESET the reading) of this info when booting the printer so that I can refill my cartridges or use other almost identical cartridges made for the same engine but without the Xerox chip?
          Part B -- The Brother HL-4200cn & QMS Magicolor 3300 toner cartridges are identical except for small external "tab notches" in the toner housing that can easily be modified to fit, but is the toner ID/count device the same? If not, part A above applies to these cartridges as well, so that I can buy the least costly toner and use with Phaser 6250!
          THANK YOU for any help & tips you can provide!!
          RFaxMan at yahoo
