WorkCentre 7845 "Some Network Services Involving A Parallel Port Are Not Available"
  • RudyNYC
    • Mar 2010
    • 13
    The display (UI) keeps displaying this message... "Some Network Services Involving A Parallel Port Are Not Available" it also show on the computer monitor when they send a print job. How can I get rid of this?
    TIA
  • shinchan
    • May 2011
    • 195
    Re: WorkCentre 7845 "Some Network Services Involving A Parallel Port Are Not Availa
    are you using standard tcp / ip port?
    please check in the:
    1. devices and printer
    2. select printer workcentre 7845, right click. choose printer properties
    3. select port tab. it should be using ip address as port name.
    • Murv
      Sr. Escalations Analyst
      • Mar 2021
      • 182
      Log in as admin and try a software reset. And/Or update the FW.
      • Jettdog
        • May 2021
        • 48
        Enter CSE Diags
        Adjustments
        dc301 NVM Initialization
        Select network and all then select initialize
        • Murv
          • Mar 2021
          • 182
          Originally posted by Jettdog
          Enter CSE Diags
          Adjustments
          Might want to make sure you have a current config page and a clone file before you pull that trigger. You might also end up dumping into non-customer mode and will need to set 616-014 to 2.
