Hello,
This is my first post in this forum. I will appreciate it you would have a look to the issue I am facing. As a welcoming nod, any suggestions would be welcome!
I have been having this issue ever since I bought my multifunction printer. I have the printer connected to my LAN though a router. There are 2 Windows and 2 OS X machines on the LAN. I am using Xerox-supported drivers when printing from Windows, while I have installed Gutenprint opensource drivers on the OS X laptops. I can successfully print from all computers.
The issue I am facing has to do with ethernet speed: All devices report Full Duplex, 100baseTX ethernet types, M118 set to auto ethernet speed reports 100baseTX as well, I am experiencing VERY SLOW speed when the file is being sent to the printer. Even with 10baseTX, I would expect a speed around 1MB/sec. I am actually getting less than 300KB/sec transfer rates, meaning that some 10MB files I am printing take around 6 to 7 minutes before they get transferred to the printer.
I would like to add that the issue occurs ONLY when printing through ETHERNET. Using a USB cable seems to fix the problem, but using a USB cable unfortunately doesn't suit my office configuration well. I have contacted Greek Xerox support by phone many times and they seem unable to offer me a solution. They seem to focus on image quality and driver options, which is not the problem, since through USB the 10MB files I am referring to is being sent in around 10 seconds. A colleague of mine -to whom I recommended the same workcenter model- is facing the EXCACT SAME PROBLEM under his office configuration, somehow different from my own, although still trying to print through the ethernet port.
