Xerox Copy Centre C35
  • tcypy1961
    • 773
    I am getting some error codes on the machine and they are: 11-140, 03-700, 03-777, and 03-780. The code the comes up the most out of the 4 is the 11-140. The others are just sparatic. I was wondering what these codes are and what to do to fix my problem? Another problem I am having is that I tried to disconnect their finisher from the machine to see if the problem was in the finisher or copier. But when I disconected the finisher the copier wouldn't copy because it was basically still looking for the finisher, eventhough it was disconnected. Was wondering if there is a setting that has to be changed to let the copier know the finisher is no longer attached or is the a problem? Any help appreciated, thank you.
  • xcopytech
    • Aug 2006
    • 1792
    11-140 is error code related to finisher.
    to isolate problem disconect finisher and on finisher connector on machine connect pins 3,11 and 13.
    this will enabe machine to work without finisher.
    there is no other way to disable fiisher
    br
