V180 - Fault code 094-312
  • MHeon71
    • Oct 2008
    • 489
    Cannot get rid of this fault code.
    Receive call for 094-312. Toner is everwhere in the back because the toner clumped in waste collector pipe causing the main auger bushings to pop out and some of the caps to come off, spilling toner.
    I replaced the waste collector pipe, 2nd BTR and MCU PWB. I have done a good amount of cleaning and I have cleaned out the connectors multiple times and still remain with the code.
    I inspected the funnel and elbow assembly and they seem to be in place. I have done what the manual asked and same issue.
    Any help would be appreciated.
  • azehnali
    • Nov 2009
    • 679
    Re: V180 - Fault code 094-312
    does the btr retract ?
    • xcopytech
      • Aug 2006
      • 1794
      Have you tested 2nd btr clutch from diagnostic?
      Do yo have any other faults in fault history?
      • zara
        • Jun 2021
        • 13
        It's all about 2nd Btr reconnect the 2nd Btr and check if the error code popup again remove 2nd Btr and restart machine and check the error code
        Sent from my SM-M315F using Tapatalk
        • MHeon71
          • Oct 2008
          • 489
          I am checiking that now. It was last week. When I just checked again, it was not. I went through to check connectors because I went in through that area to clean the connectors in the back.
          • MHeon71
            • Oct 2008
            • 489
            No other related fault codes, just ones from my own stupidity. Like forgetting to plug the OHCF power back in or IIT from forgetting the cable to the IIT.
            Started without 2nd BTR, same error. I did see the 2 gears in the back turning. One for the roller and the one for the retracting of the 2nd BTR.
            Install it back in, same code, but I do see the yellow flag nudging forward as if there is to much of a load.
            I will get the old 2nd BTR, just to try.
            • azehnali
              • Nov 2009
              • 679
              nudging means its not turning
              there is your issue
              look into and fix
              • xcopytech
                • Aug 2006
                • 1794
                Check 2nd btr retract clutch.
                • MHeon71
                  • Oct 2008
                  • 489
                  I will be getting main motor assembly. I swapped the motor with a drum motor and I cleaned out all the gears of toner junk, same thing. Without 2nd BTR, both drive gears turn, with the 2nd BTR, it looks like it tries but fails. I am ordering main motor assembly. Thanks for your help and I will update soon.
                  • MHeon71
                    • Oct 2008
                    • 489
                    Replaced the main motor assembly and it worked.
