Swap Xerox WC 7120 ADF to Xerox WC 5330 ?
  • mojorolla
    The Wolf
    • 2626
    I was wondering if this is an easy swap, as I show the part numbers are the same (059K71382) or, does it require a firmware flash, setting or board change as well?
    Thank you in advance.
  • shinchan
    • May 2011
    • 197
    Re: Swap Xerox WC 7120 ADF to Xerox WC 5330 ?
    check the ADF pwb version. if different, you need to swap the ADF PWB.
    swap the ADF PWB together with the 2 plug jack going to the IIT board on the backside of the machine.
