Xerox WorkCentre 7225i not working
  • eagles
    • May 2022
    • 4
    Hello all forum members.I have a problem with a xerox workcentre after a power outage.I tried to rewrite the firmware but I can't, I don't boot from the usb stick.I'm adding a video of the issue.Please help me.Thanks a lot
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox WorkCentre 7225i not working
    What code you have on 7 segment display on ESS PWB?
    • eagles
      • May 2022
      • 4
      • xcopytech
        • Aug 2006
        • 1794
        Have you tried forced upgrade altboot
        • eagles
          • May 2022
          • 4
          Yes, but do not charge from the USB stick.Can you tell me which USB stick to use and what steps to follow?
          • eagles
            • May 2022
            • 4
            USB ports are not powered..does not recognize the usb stick
            • adriansto
              • 2389
              Try to replace machine hdd ( incearca sa inlocuiesti harddisk-ul ). Check thre are all voltages on SBC pwb.
