Xerox Versant 180 error 024-983 and 013-246
  • azehnali
    • Nov 2009
    • 679
    anyone have a solution for this
    the booklet tray says empty tray after 18 booklets
    changed the booklet tray and cable and same error
    thanks
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox Versant 180 error 024-983 and 013-246
    What software version is on machine?
    • azehnali
      • Nov 2009
      • 679
      It has the latest software version the one that ends in 53
      • azehnali
        • Nov 2009
        • 679
        80.53.73 is the software level
        • xcopytech
          • Aug 2006
          • 1792
          I do not think that is the latest SW.
          80.55.13 is the latest which I have.
          • azehnali
            • Nov 2009
            • 679
            can I get a copy
            do you think thats one of the fixes?
            thanks
            • azehnali
              • Nov 2009
              • 679
              are you sure this is not the latest version for the 180?
              80.53.93
              • xcopytech
                • Aug 2006
                • 1792
                For versant 180 latest sw start with 80.55.xx
                First sw was 80.33.xx then second was 80.54.xx
                • adriansto
                  • 2384
                  80.53.93
                  These are firmwares for V180. Confirm 55.13 is latest.
                  However I dont think the error you have is software related. I double check the wires, connectors and switch.ScreenHunter_1429 Jun. 08 10.00.jpg
                  • xcopytech
                    • Aug 2006
                    • 1792
                    80.53.93
                    Sent you mail with link for sw 80.55.13
                    • azehnali
                      • Nov 2009
                      • 679
                      However I dont think the error you have is software related. I double check the wires, connectors and switch.[ATTACH=CONFIG]53578[/ATTACH]
                      I will recheck the wires
                      the machine has the squarefold trimmer for not much other than the cable that does to the finisher to check
                      I have replace the USB Cable because the booklet tray was not running
