Xerox Versant 180 Registration
  • azehnali
    • Nov 2009
    • 679
    What is the best way to adjust registration
    whatever I try 13x19 card stock is always off
    thanks
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Xerox Versant 180 Registration
    create a customer alignment that works, name it and point to it through your custom paper setting.. i've found Xerox offers a LOT of control but you need to know how to utilize it. Kind of like Linux vs Windows.
    • azehnali
      • Nov 2009
      • 679
      that does not work
      • jhalfhide
        • Apr 2015
        • 454
        SIQA is absolutely brilliant. It'll only work within a finite window though, so if it's too far out initially you will need to do the System Registration in service mode to set the baseline.
        Also, there could be physical issues that cause wandering registration. What tray are you running from? Tray5 has double the tolerances of other trays.
        Sent from my LYA-L09 using Tapatalk
        • azehnali
          • Nov 2009
          • 679
          I think I have to do the system registration but I have never been able to do it right
          what is the best procedure for doing it?
