Xerox Versant 180 Magenta issue
  • azehnali
    • Nov 2009
    • 679
    On the Xerox 180 the magenta color is off registration
    you can see the defect on the IBT belt
    replaced the M/Y ros ,IBT assembly ,whole developer tray ,all drums ,fuser assembly and BTR
    same issue
    also upgraded software and reset IOT nvm
    any one have any ideas?
    thanks
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: Xerox Versant 180 Magenta issue
    I would swap the drum drive with another color and see if problem follows. I had this on a c70
    • azehnali
      • Nov 2009
      • 679
      I swapped it with cyan and same thing
