9-597-0 Altalink B8075
  • JeeDayHS
    • Jan 2021
    • 18
    [Error Code] 9-597-0 Altalink B8075
    Toner control Fault, I need help with this code, got this problem on 2 Altalink
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    Re: 9-597-0 Altalink B8075
    Same engine:
    Xerox WorkCentre 5945, 5955 - Toner Cartridge Problems
    • JeeDayHS
      • Jan 2021
      • 18
      Allready Change: Drum, Toner, Toner Dispenser, only left to change is Motor 607K29040
      • Murv
        • Mar 2021
        • 182
        Did you reset the NVM value?
        • JeeDayHS
          • Jan 2021
          • 18
          yes
          • Murv
            • Mar 2021
            • 182
            What happens with a 093-040? That should tell you the status of the motor.
            • JeeDayHS
              • Jan 2021
              • 18
              Work fine toner move
              • JeeDayHS
                • Jan 2021
                • 18
                093-045 Only 2 litle moves like about 5mm, its that corect or need to move all 60 seconds like 093-040?
                • Murv
                  • Mar 2021
                  • 182
                  If you are saying that the drum motor barely moves, then I would say you either have a bind or possibly a bad print cartridge motor.
                  No offense, but you seem to be burying the lede - Can you give a full rundown of which diagnostic procedures you have run? Also, what is in the fault history? Faults in the log will give you a good idea of which fork in the road to take.
