xerox 700 integrated fiery software will not reload
  • mntech
    • Aug 2010
    • 250
    I have a xerox 700 with the integrated fiery E100-05 that wont boot.
    I was able to get a a copy of the system software dvd iso image
    I put the fiery dip switches to on, hook up a crossover to my computer, run the installer
    The fiery connects to my computer via FTP and loads a couple files (vmlinuz, diablo.initrd.gz)
    Says ready
    uncompressing linux.... OK, Booting the kernel.
    then never goes past that. I've tried the orginal HDD and a new blank drive as well with no luck.
    Any help would be great!
    Thanks,
    MNTECH
  • adriansto
    • 2384
    Re: xerox 700 integrated fiery software will not reload
    On your PC display appeared the message:
    The installation has finished successfully ?
    Do you use dvd unit or mounted iso file ?
    What you described seems like Fiery try to boot from your PC.
    • mntech
      • Aug 2010
      • 250
      I mount the iso as a virtual dvd on the PC
      The progress bar on the PC software install never goes past 0% and after 10-15 min says failed
      I've also made sure to disable firewall and do not have any other ftp services running
      I will try to get a couple pictures uploaded
      • xcopytech
        • Aug 2006
        • 1792
        Try with usb installation
        • mntech
          • Aug 2010
          • 250
          Case closed
          The problem was that I actually have a 700i
          And I need a different software for it
