can you help me for this problem workcenter 7545 green
  • bahamid
    • Feb 2012
    • 23
    i start up my machin but When the unit first attempts to boot, we get the Green image. Then after a few moments, it changed to the pink screen, and asks to be Reset. We have attempted Resets several times, and continue to get the same message. Do you think this has something to do with the HDD? we were not able to test the machine before. Any advice what is causing this problem? thanks.
  • adriansto
    • 2369
    Re: can you help me for this problem workcenter 7545 green
    [There is a little led display. What error code show it ?
    • bahamid
      • Feb 2012
      • 23
      Nothing Just This Picture
      • xcopytech
        • Aug 2006
        • 1783
        Small led display on right side of machine
        • Murv
          Sr. Escalations Analyst
          • Mar 2021
          • 180
          As noted above - Post codes on the 7 segment LED will point you in the right direction.
          • bahamid
            • Feb 2012
            • 23
            yes led dsplay few minutes and stop it
            • xcopytech
              • Aug 2006
              • 1783
              If you do not know differences between power save button and 7 segment led display on SBC pwb I think you should call a tech
              • Murv
                • Mar 2021
                • 180
                Originally posted by bahamid
                [ATTACH=CONFIG]54173[/ATTACH]
                You know where you plug in the network cable? That would be the SBC. Your 7 segment is there. Do you have an eDoc? Not to be an ass, but this is some low level, newbie troubleshooting here. Look at the post codes on the 7 segment while the machine is powering up. Eventually it will settle on a single digit. Look it up in the eDoc and follow the RAP.
                • bahamid
                  • Feb 2012
                  • 23
                  yes led dsplay
                  • Murv
                    • Mar 2021
                    • 180
                    [ATTACH=CONFIG]54184[/ATTACH]
                    yes led dsplay
                    What is listed in the error log?
                    • bahamid
                      • Feb 2012
                      • 23
                      nothing
                      • Murv
                        • Mar 2021
                        • 180
                        nothing
                        I find that hard to swallow. If there is nothing in the error log that means that machine has never had a paper jam, unexpected power down, or anything. You are saying that it has operated PERFECTLY since it was turned on. Sorry, but I've been working on these things for a very long time and I cannot buy that for an instant.
                        Press Machine status
                        Go to faults
                        Go to current faults > post a pic
                        Go to fault history > post a pic
                        I gotta see this for myself.
                        • bahamid
                          • Feb 2012
                          • 23
                          Go to faults
                          thanks error fixed
                          • Murv
                            • Mar 2021
                            • 180
                            thanks error fixed
                            And the error was?
                            • bahamid
                              • Feb 2012
                              • 23
                              And the error was?
                              This
