A client of mine has 2 Xerox 5325 in different locations. They print from the PC's via network, and also from android phones via network.
It worked fine until a few months ago, when it started showing error 016-751 randomly when they try to print from android phones.
Some files work, other don't. I can't find a pattern, but I think the problem is with the larger files, the ones with multiple pages, even if the file size is not big (pdf's).
The client said this started happen after some software updates on the phones, but I can't really trust his judgement. He also said that it works from some old phones.
Nobody has an IOS there, so I don't know if it's only android related.
The thing is, the copiers work fine from PC's via network, but when they try to print form android sometimes they work, sometimes they don't.
The error is 016-751, and I found that it means: "Fault Code 016-751: There is Insufficient Memory When the PDF Direct Print Function Print Mode is Set to PostScript".
I already tried to Increase the PostScript Memory on the Machine to the maximum, but no change.
If anyone has any idea I'll be happy to try anything...
Thank's!
Thank's!
