code error 042-324 xerox versant 180
  • Ninis
    • Oct 2022
    • 2
    [Error Code] code error 042-324 xerox versant 180
    hi, i have a problem with my xerox versant 180, sometimes it does this code (042-324) when i restart sometimes it's works sometimes it doesn't and when it works it's just print a few copies and it display the code again.
    thanks for the help.
  • elsab
    • Dec 2007
    • 63
    Re: code error 042-324 xerox versant 180
    Error code related to ibt home positioning while rotating. Try to clean the ibt belt patch to correctly sense by home position sensor, clean the inside rolls (BUR, 1st btr's) of ibt and the ibt cleaner for friction that may slow rotation.
    • xcopytech
      • Aug 2006
      • 1794
      042-324 is related to ibt drive motor.
      • zagrex
        • Dec 2011
        • 63
        • InterfaceP
          • Jun 2013
          • 488
          Make sure the BUR nose isn't broken where is connects to the fly wheel
          • Ninis
            • Oct 2022
            • 2
            Hi, thanks for your help, i cleaned the btr, i made some prints and it's worked well, i will keep you on new
