Xerox workcentre 7225
  • nathicana
    • Aug 2008
    • 329
    We have a Xerox 7225 that has to be returned to the leasing company. When I turn it on the screen quickly comes up stating "Please wait...system is powering up do not press power button again while power up is in progress." It stays that way indefinitely without running or progressing to a ready state, still displaying that message. The help light is flashing all the time.
    I've tried restarting, same result. We are not a Xerox dealer and I know next to nothing about this machine. Does anyone have experience with this problem?
  • clokworkpenguin
    • Sep 2017
    • 7
    Re: Xerox workcentre 7225
    Most likely a faulty hdd. You can try reloading firmware using the altboot procedure before replacing it to try and get it good enough for the leasing company
    • xcopytech
      • Aug 2006
      • 1792
      What code you have on 7 segment display
      • nathicana
        • Aug 2008
        • 329
        Looks like a u with a flashing dot to the upper left. See picture, that's the only 7 segment display I find.
        • nathicana
          • Aug 2008
          • 329
          Thanks Mr. Penguin. Can you describe the altboot procedure and where on the equipment the hard drive is located in case I have to replace it? Do I have to format the new hard drive in technician mode?
          I think I just downloaded the correct firmware from the Xerox site.
          • xcopytech
            • Aug 2006
            • 1792
            Download firmware from xerox site.
            On usb stick create folder altboot
            Copy firmware dlm file to altboot folder.
            Put usb stick in machine and power on machine
            Firmware upgrade should start for a couple minutes
            • Jack79
              • Jul 2014
              • 312
              HDD is located at the back on the right. Loosen 2 flat (not philips) screws and open rhe cover.
              Try altboot first like described above.
              • nathicana
                • Aug 2008
                • 329
                Thanks for the replies. The firmware upgrade worked and the machine comes to ready now. For a while it behaved erratically, restarting unexpectedly a few times. Then it went into a data encryption sequence all by itself. Just before I went home yesterday I ran some copies then did an on demand full image overwrite and deleted the contacts in the address book.
                One thing that bothers me is that the document feeder does not work, it keeps asking to "Lower the document feeder" when I place originals even though it is down. Yesterday I know I fed an original and made a copy. The black arm that the feeder actuates when lowered causes the scan lamp to turn on and move so I assume there is another switch somewhere that tells the machine the document feeder is down. I might be able to skip fixing this but I would like to anyway if someone knows what I should check.
                I appreciate the help so much. I don't think I could have figured this out on my own.
                • clokworkpenguin
                  • Sep 2017
                  • 7
                  There's a magnet in the front cover of the adf. If you have the front cover off or the magnet is missing, it will declare that the adf is open.
                  • jhalfhide
                    • Apr 2015
                    • 451
                    Cracked hinges. Known issue on this model. The hinge mounts crack and mean the black plunger isn't pushed down quite far enough. You can sometimes buy yourself a bit longer by gluing a small coin to the underside of the raised ADF so it presses the black plunger better.
                    The proper fix is to fit the hinge repair kits
                    hinge repair kit right - 00655N524
                    hinge repair kit left - 00655N532
                    Sent from my LYA-L09 using Tapatalk
                    • Jack79
                      • Jul 2014
                      • 312
                      Stick something above actuator.
                      You can also press down adf where actuator is located to test.
                      If you noticed unexpected behaviour after altboot then your hdd can be failing
