Boot up the machine and COPY and SCAN is greyed out. At the top of the display its says:
A fault has occurred
Some features may be unavailable
Please contact the system admin
When I go into the System Panel and go to look up the faults it says
Select a report/list you want to print and press Start
The only option to select is Error History Report but its greyed out.
Quick run down on the machine: Just got the machine in yesterday, booted up fine and said the Drum Cartridge needed to be replaced. We replaced it and got the above errors. Machine has 40k copies on it.
