Hi everyone I have a Xerox WC 7855 producing faint (light) copies at the bottom and top photocopying and printing even when i make solids pattern prints from daigonositic mode all four colours are affected I have tried to change transfer belt all four drum all four developer materials 2nd btr But still the problem is still there what could be the problemIMG-20221215-WA0040.jpg
Faint copies
Re: Faint copies
Hi everyone I have a Xerox WC 7855 producing faint (light) copies at the bottom and top photocopying and printing even when i make solids pattern prints from daigonositic mode all four colours are affected I have tried to change transfer belt all four drum all four developer materials 2nd btr But still the problem is still there what could be the problem[ATTACH=CONFIG]55908[/ATTACH] -
Re: Faint copies
I had a similar problem last week on a Xerox 7845. The fuser was causing it. Can you change the fuser?Comment
Re: Faint copies
I got another working fuser unit from another working machine still it's faint on the side and the same fuser unit worked Okey on another machineComment
