099-375
+ More Options
Posts
  • Reeves
    • Apr 2012
    • 294
    [Error Code] 099-375
    Hi I have Xerox V180 with error code 099-375 its something to do with fuser unit help what exactly is coursing this error
  • Tomek
    • Nov 2022
    • 6
    Re: 099-375
    Hello
    Check the following:
    • Operation failure of Internal Roll Sub Lamp (dC330 [010-013]).
    • Abnormality in the Internal Roll Thermistor 1/2 (dC140 [010-206/207]).
    • Falling off, contamination, foreign matter clogging of the Internal Roll Thermistor 1/2.
    • Open circuit, short circuit or poor contact of the connection between MCU PWB J406 and the Internal Roll Thermistor 1/2 P151A.
    • Conduction of Internal Roll Thermostat 1, 2.
    During Fuser Warm Up, I/R Center Lamp continues to be On for the specified time period or longer (NVM). Time Out Fail as I/R did not reach the target temp within the specified time period (NVM).
    1. Check the contamination / paper debris / Foreign material adhesion at the temp detection area that turns I/R Lamp On/Off
    2. Check the following in order:
      1. Check SNR harness damage / short
      2. Open Thermostat circuit
      3. Check the temperature detection circuit
      4. Check LV power
      5. Check I/R Lamps On/Off.
      6. Check I/R Warm-up control temperature NVM variation [744-665]
      7. Check GFI breaker for Fuser Lamp
      8. Check Fuser AC Relay
    3. Replace the Fuser Belt Unit
