116-332 error to dcc400
+ More Options
Posts
  • smiley
    • Aug 2008
    • 616
    hi guys i have the error for this machine.anyone please help me.
    there is no glory without sacrifice
  • copytech200X
    • 264
    this fault code invalid log info first, u need removed hdd then power on machine. wait until machine comes out fault then power off machine. install hdd again,if fault code reappears then u need connect laptop and lauch PSW go to hdd diag dc355.i suggests u bring one working condition hdd to test to minimize downtime call...good luck
    • smiley
      • Aug 2008
      • 616
      thanks for quick reply xcopytech200x.i will try your sugestion.thank you soo much.
      • smiley
        • Aug 2008
        • 616
        hi xcopytech200 the code comes back evry time i turn off the machine.now i try to used psw in my loptop but it only the dummy is all i can use the other one got error it says different machine i try to reload firmware but the machine when i try to boot the machibe it always go to download mode.please help me what i need to do?
        • TechMate
          • Mar 2008
          • 285
          Hi. Turn off the machine. Remove the HDD. Reboot until the machine reaches ready mode. If no buttons are greyed out, then you must replace the HDD as it would be faulty.
          But if you replace it with a new HDD and the fault comes back, it would be a faulty IDE interface board or a faulty ESS board.
          But before replacing any board or HDD, do an NVM reset first and repeat the above procedure. Last resort is replacing components
          • smiley
            • Aug 2008
            • 616
            thanks for the help freind.i will try what you suggest.i will let you know what the result.by the way what i will going to do if there is a coler displacement in this machine.thanks
            • copytech200X
              • 264
              if color out of alignment u need refer back tray 1 a small slot contains all color registration ..just input the setting value ..hear fr u soon..
              • johnner66
                • Mar 2009
                • 265
                try this power off m/c then hold now ket 4/stop/poweer save together n power on the m/c it work for you good luck ,.,.,.
                • smiley
                  • Aug 2008
                  • 616
                  hi guys thanks for all your help i appreciate it.thanks but the costumer call a xerox tech and according to him they replace the board where the roms and hdd are connected.thanks.
                  • TechMate
                    • Mar 2008
                    • 285
                    That's the ESS board if you're following what I was getting into
