Xerox C75 045-314 fault code
  • cpress
    • 37
    I have been servicing my C75 since I quit using Xerox service. I am now getting a 045- 314 code , IOT sequence time over. How serious is this?
    I use this machine as a back up to the Ricoh and any overflow work when we get really busy.
    If it involve an expensive fix I will get rid of the machine, the Fiery EXC75 controller has very little use as it was used to replace the free flow.
    TIA,
    David
  • adriansto
    • 2383
    Re: Xerox C75 045-314 fault code
    TIA,
    David
    Most of the time black drum or black corotron cleaner = replace corotron.
    • cpress
      • 37
      Replaced corotron and it worked!!! Thank You!
