092-320 Error Code on Versalink c 405
  • tekkie
    • Mar 2011
    • 112
    [Error Code] 092-320 Error Code on Versalink c 405
    Hi Guys
    I have a Versalink c405 that gives 092-032 error code and says replace cyan toner
    I have a few of these machines that have done this in the past but seem to get it going by trying the toner severaL TIMES AND ONCE IT TAKES IT ITS FINE.
    I am aware of metered and non metered toner and its def the right type
    I have tried 3 different toners I have cleaned and made sure the gold pins in the mc that read the chip are clean and not bent
    The mc powers up and thinks about it but then just says replace cyan toner
    When you go in supplies it says cyan toner is 100% when I put the new toner in.
    I have checked cyan drum all seems ok Have hit a brick wall with this one
    Any help appreciated
    Have checked edocs and doesnt give much info at all
  • adriansto
    • 2387
    Re: 092-320 Error Code on Versalink c 405
    Originally posted by tekkie
    Hi Guys
    Bulletins 1433905 and 1403357
    • tekkie
      • Mar 2011
      • 112
      I will check these when I go back thanks
      • cyberpunk
        • Feb 2023
        • 2
        Здравствуйте, вам удалось решить проблему?
        • Apouthe Donald
          • Mar 2014
          • 82
          Hello have you tried to replace the cyan drum?
