Error code 092-320 Versalink c405
  • cyberpunk
    • Feb 2023
    • 2
    [Error Code] Error code 092-320 Versalink c405
    I replaced the cartridge and the drum unit (drum), rearranged the chips, and the error 092-320 does not pass, is there anyone here who has encountered such a problem, how to fix this problem?
  • tech9
    • 216
    Re: Error code 092-320 Versalink c405
    make sure you are using genuine Xerox Toner.
    And that the toner is dispensing correctly.
    If not then you have block or faulty dispenser.
    Worst case a faulty ROS.
    • Tech-Yeah
      • Nov 2022
      • 8
      Did you print a color separation test? If your Cyan is light, you can increase its density by running its toner motor.
