Primelink 9065 Direct Pipe Assembly
  • Paulo Borges
    • 16
  • Dech1
    Senior Engineer
    • Dec 2022
    • 61
    Re: Primelink 9065 Direct Pipe Assembly
    1. Disconnect all cables connected to the Controller PWB. (Figure 2)
      • Disconnect the connector (x2).
      • Disconnect the USB Cable.
      • Disconnect the Flat Cable (x2).
      • Remove the cable from the CONT Harness Guide.
      • Release the cable from the clamp.
      • Remove the USB cable from the USB Harness Guide.
      • Remove the screw.
    2. Open the HVPS Unit. (Figure 3)
    • Paulo Borges
      • 16
        • Remove the screw.
          [ATTACH=CONFIG]56948[/ATTACH]
        • Loosen the screw (x3).
        • Open the HVPS Unit.
          [ATTACH=CONFIG]56949[/ATTACH]
      Many Thanks, Dech1
