Xerox D125 error code 077-142
  • VINCENT23OMAN
    • May 2021
    • 14
    [Error Code] Xerox D125 error code 077-142
    Does anyone encountered this trouble? Already replaced the sensors in registration area. Also the paper will be on the top of the duplexing unit when the machine encounter this error. Already tried to clean the decurler aswell as the duplexing unit
  • xcopytech
    • Aug 2006
    • 1786
    Re: Xerox D125 error code 077-142
    77-142 is fault code for pre transfer sensor. Test sensor from diagnostic mode.
    • adriansto
      • 2377
      Also check this:
      • VINCENT23OMAN
        • May 2021
        • 14
        greetings and good day fellows, thanks for the ideas and suggestion. Upon thorough checking of the machine I found this stepper motor which is in the registration drive assembly broken. Will update if the error will be gone when the parts arrive and after I install the new motor
