ERROR CODE - Xerox 7120 error code 061-334
  • vic4we
    • Mar 2023
    • 15
    Hi, been getting this error code lately. And the machine needs to be restarted. Then a couple prints and again. Debating if it's the fuser?
  • adriansto
    • 2383
    Re: ERROR CODE - Xerox 7120 error code 061-334
    Ros laser control with problem. Try to reseat the connectors PJ401 on MCU pwb and PJ401 on LD pwb ( on lateral side of ROS unit ). Usually you must dismantle the ROS unit and clean inside including rotating mirror and diode from LD pwb carefuly.
    • vic4we
      • Mar 2023
      • 15
      Not a Full Tech. So trying to make sense of what u said. I did open the ROS unit and cleaned the mirror gently last year. But I guess I can try doing it again. Thanks will update later. UMMM can u provide a pic of the PJ401 connectors?
      • vic4we
        • Mar 2023
        • 15
        Hi I checked wires at the ROS unit and even vacuumed area.... It worked for like an hour then gave a a 041-323, then went back to 061-334...... Any other suggestions?
        • adriansto
          • 2383
          Not found 41-323 code. Are you sure this is the code ?
          • vic4we
            • Mar 2023
            • 15
            I may have mis-quoted the digits but that was resolved....It was the black drum sticking (041-323can't remember). But when I opened machine checked the wires of the ROS panel..... I noticed that my magenta 'dispenser head' from the toner to the drum was stuck, which at some point before made my last magenta toner leak. I fixed that. Then the machine worked awesome for like an hour then the 061-334 . I do hope that's enough details.
            • vic4we
              • Mar 2023
              • 15
              DAMN..... NO ONE KNOWS?
