system error wc7845 after replace cyan developer
+ More Options
Posts
  • ps22sp
    • Aug 2014
    • 83
    after replace cyan developer a flat cable socket not connect
    cause the code 392.312.00 392.313.00 392.314.00 system error message
    how to erase error message thanks
    drum and developer motor unit noise ,plastic gear (developer drive gear damage ) and replaced whole motor unit
    on the back blue cable not installed , machine output blank no image on paper,
    plug in blue cable ,, machine run ok ,but cyan developer check ,then in front , one cable not install
    the screen error history 392.312.00 392.313.00 392.314.00
    clear the value in nvm data 752 346 752.347
  • ps22sp
    • Aug 2014
    • 83
    Re: system error wc7845 after replace cyan developer
    problem solved
    392,312.00 (yellow) 392.313.00 392,314.00 (magenta), 392.315.00 (black)
    enter into service mode change value in nvm
    752 346 (yellow) 752.347 752.348 . 752.349 (black) are normal according black data in nvm
    change value in nvm color 1 to 0
    machine test OK
