Xerox 240, Fault Error 042-328
  • gooch4prez
    • Mar 2009
    • 10
    Does anyone know what this fault code means?
    042-328
  • xcopytech
    • Aug 2006
    • 1783
    Belt Edge Sensor Failure
    • gooch4prez
      • Mar 2009
      • 10
      Belt Sensor
      What makes the belt slide from top to bottom? The belt slowly moves towards the front of the machine after time.
      Side note: Back up and running!
      • copytech200X
        • 264
        you need do proper alignment when u removed ibt belt and make sure top and bottom are equally balance .
        • johnner66
          • Mar 2009
          • 265
          make sure the silver tag inside the belt is at the sensor side v
          • johnner66
            • Mar 2009
            • 265
            dcc450
            no display on panel exposure ok interrupt botton blinking any tip thanks
            • TechMate
              • Mar 2008
              • 285
              Try replacing the panel. If still not going, replace the LVPS unit @ the back
              • WIWA
                • Mar 2009
                • 97
                Hello, check for belt inside patch clean it up use presurize gas to clean up sensor put it back and perform belt learn routine from UI.
                hope this help,
                Wiwa72
                Gonzos build v1.0
                • TechMate
                  • Mar 2008
                  • 285
                  042-328
                  Belt edge sensor failure. make sure the silver patch is cleaned. and the IBT cleaner free of excessive toner. Don't forget to reset NVM 741-105 to 0
                  • china
                    There is no the type of machine in China.
                    • TechMate
                      • Mar 2008
                      • 285
                      That will be the equivalent of a DC5065
