Xerox 6655
  • Hoosierdaddy
    • Oct 2016
    • 181
    Xerox 6655
    Machine is not going thru Inital. Has green light on and gets so far and starts over. Is this the Hard Drive? If so is the hard drive hard to replace and is there steps to do after replacement?
    Thanks Hoosierdaddy
  • xcopytech
    • Aug 2006
    • 1786
    Re: Xerox 6655
    On machine left side under network port remove small cover.
    You will see 8 leds. Post here picture to see what is wrong with machine
    • Hoosierdaddy
      • Oct 2016
      • 181
      Re: Xerox 6655
      The Top 4 Lights are Yellow and the bottom 4 are green if that helps solve the mystery.
      Hoosierdaddy
      • adriansto
        • 2377
        Re: Xerox 6655
        Hoosierdaddy
        This means that the machine hdd is probably defective. It must be replaced and reload machine software.
