Hello Guys Help With Xerox DC250
  • eng_usama
    • 115
    The machine work well but only when print or copy the first copy is good and clear
    The 2nd copy give two band of color magenta and yellow always same place and same shap no difference
    The attach can describe the problem hope someone can help
    I change drum I clean laser I did maintenance for transfer sheet cc lean ros
    No luck
  • Gaffers01
    • May 2011
    • 334
    Re: Hello Guys Help With Xerox DC250
    Stop the machine mid copy and have a look at what image is on the drums, I know you said you changed the drum BUT I would look at them first.
    • eng_usama
      • 115
      Thanks for your answer but tell me what is the difference if the drum have the same photo on it
      ? Remember it is only in the 2nd copy 1st copy is clear
