Phaser 6180 - Unfused / flaking toner with labels
  • nullvalue
    • Apr 2023
    • 5
    Hello, I have a Phaser 6180 which is still working great - but I print a lot of color labels. Sometimes small portions of the toner doesn't fuse well and flakes off the paper. I am aware that I need to select the correct paper type, but I am having issues with that..
    On the printer, I go to the tray settings and set the correct paper type to "Labels". Save that.. then when I print, the printer itself throws an error and tells me to insert plain paper. It's as if my computer is telling it the paper type instead of taking the setting that I saved at the printer.
    Even more frustrating, there is nowhere in the printer dialog/settings/driver to select the paper type I'm using. I've reinstalled the drivers, installed used a different computer/laptop - yet I can't find an option to set the paper type..
    Has anyone run into this or know how to help? Thanks!
    • 22801
    Re: Phaser 6180 - Unfused / flaking toner with labels
    in the program you're using, what is the media type for that tray? set it for labels ... computer always overrides printer settings.
    • nullvalue
      • Apr 2023
      • 5
      Thank you, I'm using MS Word. The problem is that I don't have an option for paper/media type anywhere. Not in the printer settings, page setup, printing defaults.. nowhere.
      I've reinstalled drivers several times too and used a totally different computer - same thing.. no option for paper type.
      • xcopytech
        • Aug 2006
        • 1783
        Do you use postscript driver
        • nullvalue
          • Apr 2023
          • 5
          Pretty sure it's PCL. Should I be using postscript?
          Actually I'm on Windows 10 and don't really get to choose, I'm forced to use this global print driver..
          • xcopytech
            • Aug 2006
            • 1783
            Try win 8 64 bit ps driver.
            You can use win 8 drivers on win 10
            • nullvalue
              • Apr 2023
              • 5
              Oh I was trying Windows 7 drivers (but it wouldn't let me) - I always forget there even was a Windows 8 lol.. I'll give that a try!
              • nullvalue
                • Apr 2023
                • 5
                Thank you! that fixed it. I got all the printer settings now and no more flaking!
